I received a Pro 106 with a blown fuse inside. It is a small surface mount fuse near the battery terminals between the negative terminal and the chassis ground. I don't have the service manual to check the value. It works fine when I short it with solder, but I think it may be dangerous to run it without a fuse. I was wondering if anyone knows what the value of the fuse is so I could replace it? Maybe 1 amp or 500 milliamp?
Thanks,
John
Thanks,
John
