Pro-106 issues
KANDCMCQ
Rolla, MO
I programed my RS Pro 106 with ARC 500 and when hooked up with vehicle power, and turn on, it works fine all day. Next day go out and turn it on and the darned thing displays "NOTHING ENABLED" . What is the issue? My RS Pro 197 does this in the house as well and it's on its wall adaptor. The programing shows which scan lists I want to scan show to be enabled.
ScannerSK
Gilcrest, CO
I have seen this a few times as well. It seems that I use to be able to press manual and then scan twice and this message would show up however it does not appear to do this anymore. Maybe one of the updates fixed the issue.
Does pressing manual and then scan fix the issue? Or, do you have to reprogram the entire scanner?
Shawn
ScannerSK
Gilcrest, CO
So, I just realized that pressing manual and then scan twice is still messing up the scanner. It will display that it is scanning when it really is not scanning at all. Very interesting...
I think they tried to fix the "nothing enabled" error however there is still some kind of small issue with these scanners.
Shawn
