sfd901
Can anyone tell me what AC adapter to use with the scanner? Also will it charge the rechargeable batteries within the scanner . Do I need a special tip for the adapter?
If you are using the "C" adaptaplug (Yellow, I think) That is the correct plug. It very well could be a defective unit.If you used a C adaptaplug and the tip was positive and the adapter was plugged into a good plug, then you have a defective rig.
