Hit PGM, then FUNC GLOB
- ((((((((Scroll down to 138-174 5KHz... make sure its set to Yes, save the changes)))))))
- Now go PGM, NEW, TGRP
- Pick your scan list #
- TSYS - New, System type is MOT VHF/UHF
- Frequencies: Hit SEL then enter the Primary and Alternate control channels for the sites you want. Hit Save when done
- T Tables: Hit SEL, then SEL again to select Table 01
* For Table 01 enter: Lo Chan 380, Hi Chan 759, Offset 380, Base 141.0150, Step 15. Hit Save when done.
* For Table 02 enter: Lo Chan 380, Hi Chan 759, Offset 579, Base 151.7300, Step 15. Hit Save when done.
* For Table 03 enter: Lo Chan 380, Hi Chan 759, Offset 632, Base 154.3200, Step 15. Hit Save when done.
this is what forts had said in the wiki and also if you got the updated firmware in the globe settings it may say canada/usa instead of 138-174 5KHz make sure it says canada that from what i understand
