Would I be better off programming in the KSP State Police in a seperate thing( i cant remember what there called) as my others, as opposed to putting them all on one? What I mean is, should I split my codes up, instead of putting them all on one.
While I'm not exactly sure what you mean, I will say how I did mine is this (short list):Would I be better off programming in the KSP State Police in a seperate thing( i cant remember what there called) as my others, as opposed to putting them all on one? What I mean is, should I split my codes up, instead of putting them all on one.
If you split things up into different Scan Lists, you'll have better control of what you want to listen to, turn on/off Scan Lists.Would I be better off programming in the KSP State Police in a seperate thing( i cant remember what there called) as my others, as opposed to putting them all on one? What I mean is, should I split my codes up, instead of putting them all on one.
YES, that's exactly what I mean. Also could someone please explain to me why I can pick up Richmond KSP which is 110 miles away clear as a bell, but can't pick up KSP Hazard which is where I live? THANKS....While I'm not exactly sure what you mean, I will say how I did mine is this (short list):
1: State Police (Troop B) [this is the Troop that covers where I live and is a P25 system]
2: Local County traffic [all of this are the local sheriff, fire, etc., traffic and is all conventional]
3: State Police (Troop A) [for when I travel to that area; normally this bank is turned off so it doesn't scan...also has its own trunking system for towers in Troop A's area, if that makes sense]
etc...
Is that what you mean? Do I have to do it that way? No. But, I like to in the event that I want to turn off the county traffic or the state traffic. Obviously I have more banks programmed with different systems, etc., but for space and time I didn't go through the entire list.
Is that what you are meaning?
Assuming that you did load the the Post 13 frequencies and not the Post 7 frequencies, did you also program in NAC 220 and 221? Been a long time since I was in Perry County. Used to stay at the La Citidale and my favorite eating spot was the Circle TYES, that's exactly what I mean. Also could someone please explain to me why I can pick up Richmond KSP which is 110 miles away clear as a bell, but can't pick up KSP Hazard which is where I live? THANKS....
