pro-106 question
exdep
Hey scanner fans I have a pro-106 and when im uploading from r/r.com I always loose the previous radio channels (scanlist) installed (saved on scanner) ..Is there a simple way to save them on the scanner??? I always have to re-do the whole thing when adding scanlists.... Thanks for any help! Mike
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Mike,
When you Upload from software (not RR) it replaces the scanner working memory with the file you sent from the software. To save what you have in the scanner, either Download from scanner and give the file a name then save it. Or, use the scanner V-Scanner options and STOR it to a V-folder.
