Pro-106 + rafb
relicwr
anyone local got this in their 106? i have the base, offset and step right. and its on mot v/u.. are the lo and hi chans supposed to be empty? cause its not seeing the cc's but it has a T receiving data from it.
N8IAA
Fortunately, GA
Press the MAN button while scanning on that Scan List. Press TSYS (F2 softkey), then press Analyz (F3 softkey). It will show you the CC's programmed into the scanner. You can then scroll through them by using the UP/DOWN arrows. That way, you will know that the frequencies have been programmed.
HTH,
Larry
relicwr
no. butel's too expensive. plus i figure its best to do it by hand so you know how to fully use it. but everything should be correct except leaving lo and hi blank.
relicwr
I put in all the channels because they rotate between the first 4 listed on RR, so I figure I just put them all in.
N8IAA
Fortunately, GA
Do you get the % reading in the Analyze mode? Are you receiving the TGID's? If so, you have the system programmed correctly. I personally wouldn't use Arc500. Win500 is better and easier to understand.
Larry
relicwr
its good enough to receive, its at 99. it wont show id's still. just sits there and scans. i thought about trying a different mot mode.
relicwr
yeah its all good now. it receives with the CC. im curious why do the hi's and lo's have to be so far apart?
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
380 is first DEC channel in Motorola scheme
Last DEC channel is 759 in scheme
Multi T-Tables would require subsequent LoCh and offset to be one DEC above previous table HiCh
with final HiCh at 759
relicwr
i see now. i thank you both for your help. only had this 2 days and its getting easier to figure out even without software. my fingers kinda hurt from all the manual input but its all good.
fmon
Eclipse, Virginia
It truly is tedious using scanner buttons but certainly gives cause to good scanner learning. However, with premium subscription and using Web Import with Win500, PSREdit or ARC500 software would import RAFB with T-Tables correctly set ready to load to scanner. Of course PS, SW and programming cable will cost 70 + bucks.
BTW, in previous question regarding lower and upper. If you chose 750 as HiCh vs 759 you would leave 9 possible freqs for voice transmissions unavailable. If your system had a frequency in the upper 9 range and CC sent traffic to that freq, it'll stop on talkgroup but without voice.
N8IAA
Fortunately, GA
Always wondered what Hi/Lo channel was. Thanks for the info, Frank.
Larry
