Hey brotha, check this link out. Indiana finished rebanding a little over a year ago or so and this has/is working for me. Its a motorola smartzone system here. (AP25 systems will populate their own tables so this is not necessary for those)
If completely done use the bottom table posted (just the two lines), if still in the midst at all, use the top table. (6 lines)
http://forums.radioreference.com/ra...6-2096-rebanded-motorola-trunked-systems.html
By the way, i too am using the Pro-106. It helped me tremendously, hope it helps you!
Edit: And to get to the T-Tables, go into PGM > EDIT > CURR, select your talk system, go almost all the way to the bottom and you'll find "T Tables," change it to custom, enter it, then enter your values! :]
Edit: Its late... I shouldve read a little more thoroughly, just apologizing for posting duplicate info! this post can be deleted!
