I just bought a pro 106 and I have programmed it using ARC500 software. I am trying to monitor Sheboygan county WI which is a motorola type II. The scanner works correctly off and on but the problem I am having is that some times the scanner picks up that someone is trying to talk but it get stuck I guess I would say. It will display the TG id and the led light will light up and also the tag will show who it is but nothing is broadcasted and the TG id will kind of flicker like it is stuck. This is a rebanded system and I think it's having the same problem my pro 164 was having when I first got it and programmed it by hand. I was told I need the software in order to make it work correctly because of the rebanding. My pro 164 works perfectly now.
I tried using the rebanding calculator but and adjusted it by -15 but not sure if that was correct. The scanner is still having the issue after trying this.
I bought the 106 because my hometown in MN uses digital now and I want to be able to listen to them when I go there to visit.
Does anyone have any idea what I am doing wrong? I don't have anything set to priority.
Here is a video of what it's doing. The talking you hear is my pro 164 next to the 106. The 106 is not broadcasting voice. You can see after the first conversation the frequency pops up on the 106 when the next transmission starts then the 106 can be heard. Then the next time a transmission comes it gets stuck again.
Click on the picture for video!!!!!!
