Pro-106 Scan List Help
marsman
port charlotte,fl.
I,m trying to get a trunked system from SCAN LIST 1 (where all conv. and trunked systems default to) into a SCAN LIST 3..The manual method,,because i do'nt have the use of a pc,, a step by step simple explanation would be greatly appreciated...also in putting in conv. frequencies do i have to put them one by one or can i group them (say as mutual aid freq.) and move them as as group to a SCAN LIST number.......thanks to all ...
rdale
Lansing, MI
All one by one. Select the talkgroup, edit the scanlist, turn off 1, and turn on 3.
pathalogical
Toronto, Canada
You will need to remove the "asterisk" from 1, go to 3 and add the asterisk. As rdale said, one by one, if you have, say, 20 objects, then you'll have to repeat the same process 20 times. Hope this helps...
