I know I probably shouldnt put two questions in one post, but i think they are fairly simple. I programmed the state skywarn freqs for CT in my Pro-106 and have set them to Priority enabled, they are also members of the scanlist 22 (skywarn). When I am scanning scan list 1 and enable Priority (PRI) it does not appear to check the skywarn freqs...does scanlist 22 need to be enabled?
Second question. SAME weather. I live in Fairfield county CT. I programmed 009001 as the FIPS code for my area. At night I set the scanner next to my bed, select WX choose stby (which then changes to STBY) do the above steps look correct? Probably no signals from NOAA have been sent and i will continue to do this until it works. I check the weather site daily to see if i missed a signal. For my own knowledge when a weather warning is issued, do they send the signal more than once? Or just the one time when the warning is issued?
Thank you,
Happy Scanning.
Thank you,
Happy Scanning.
