OK ! , a couple things , Did you take your scanner apart to dry out ? did you put the scanner in rice to dry out ? rice will soak up any moister but be sure to COVER the entire scanner in rice. Then after all that, take a test light & see if there is any juice to the speaker. Just a thought !! Good luck .
