option to combine Win500 Activity Log and GPS route text
this is 1 way I figured to combine the text from the Win500 activity log and GPS route text.
import your data into 2 excel worksheets, I found a excel plug-in from AbleBits.com called "merge tables wizard" that you select data from the 2 sheets that you want to merge to get your desired output, seleted by step-by-step wizards. I used "time" as the common feature for the merge. plugin requires you to pay, I will attemept to uninstall after the 15 day trail is up and reinstall to see if it will work again.
example attached
