stlouisx50
My Pro-106 usually will always work as soon as you turn on the unit, however sometimes it appears that the scanner is scanning everything, but it's really not. During the times it is working properly I can see most of the tags scanning through, but when the unit is malfunctioning, I only see a few tags and not all of the usual tags when the unit is working properly.
The only solution that I have found is to push the scan groups that I want to listen to off and back on, or turn the scanner off and back on.
Weird problem, but though I should list this on the forum.
