Pro-106 won't accept 801.5 - 804mhz
rudyh83634
I discovered that the scanner defaults to 806mhz if I enter anything between
801.5 and 804.0 mhz. Outside this range is ok
The spec. (users guide) says covers 764 - 806mhz with 3.125khz steps.
Anyone seen the same problem or have a fix?
kel415
Kodak,TN
pro106
Yes mine does that also, have wondered about it but guess that is the way it is. Was hoping someone would have a cure fot that. Don't ask the SHACK
DickH
Here's my guess. If it is in trunking mode it will not accept those freqs. because they are the mobile freqs. and it can't track them. You can enter them as conventional freqs.
W4EMS
Middle Tennessee
Nope, 106 will not load them as conventional either. As noted above defaults to 806.
So the GRE and 106 are not totally alike. Firmware difference?
N8IAA
Fortunately, GA
I beg to differ, my 106 and 163 both take a conventional frequency of 765.4375 with a CTCSS tone. I have to program the 163 by hand, but, the 106 takes it with the Win500 software.
Larry
DonS
Franktown, CO
With current firmware, the entire PSR-500 family (PSR-500, PSR-600, PRO-106, PRO-197) has the following 700/800MHz ranges included / excluded:
* 764.000000 - 781.996875
* 782.000000 - 790.996875
* 791.000000 - 796.996875
* 797.000000 - 805.996875
* 806.000000 - 823.987500
* 824.000000 - 848.987500
* 849.000000 - 868.987500
* 869.000000 - 893.987500
