i emailed Uniden to ask about homepatrol to see if they knew if it would work here in ABQ. here is what they sent me back:
UNIDEN Question Update :: W276697-121010Tuesday, December 14, 2010 9:02 AMFrom: "UNIDEN Support" <support@uniden.com>Add sender to ContactsTo: +--------------------------+
Your Question :
Hello,
I want to know since I cant find info anywhere, if the homepatrol scanner will work in my area, Albuquerque, NM - Police, Fire, Rescue uses the following:
System Type: EDACS Networked Standard
System Voice: ProVoice and Analog
I'd like to know before I spend over 500 $ on this unit.
Mike S.
Our Solution :
Thank you for using our system.
The software has the system information in it and it does appear to be a standard EDACS systems that is covered by the HomePatrol.
Sincerely,
