Flibmeister
- Joined
- May 20, 2003
- Messages
- 7
This is really a Windows question, I think, but the Pro-107 software is the only one I've run across with this problem, so maybe somebody else here has solved it.
I've installed the software on my netbook (running XP) and it runs fine-- but I can't see the bottom of the window where (I suspect) the tabs for Playlist, etc. are. It's as if there should be a slider on the side (like there is on a long web page), but there isn't one.
I've tried running the program fullscreen, and in a window, and I've tried dragging and resizing the window every way I know how, but I can't get it to move far enough up to see the bottom of the window. Different screen resolutions don't help, either.
EDIT: I did update the software to the latest version, doesn't fix the problem.
Suggestions?
Suggestions?
