PRO-162 - LTR Talkgroups
Tom_G
Rocky Hill, CT
Can anyone get their LTR talkgroup alpha tags to display ?
I have been unable to do so.
I have the EDACS ones working fine, but the LTR talkgroup ID's display but not the alpha tags... I double checked the ID's but no go.....
Thanks,
Tom_G
Rocky Hill, CT
I just validated that Motorola talkgroup alpha tags display fine also.
The issue appears only for LTR as or now......
spooney
Indiana
Yes, same thing with mine. Seems to be a problem with scanning in open mode verses closed mode. Even with the LTR TGID's programmed into the scanner it won't scan in closed mode on LTR. I have yet to figure it out.
Tom_G
Rocky Hill, CT
Mine scans in open mode, and it will stop on active talkgroups, but the alpha tags I have programmed in do not display. Only the talkgroup ID is displayed.
I will try closed mode also and see what that does.
Motorola and EDACS trunking systems seem to display their alpha tags fine, only LTR is a problem.
Sooooo, How do we report an issue to Radio Shack and/or Uniden ???????
mcema699
Nevermind, see you have experience in other LTR capable scanners....Post removed.
spooney
Indiana
I finally got the LTR TG alpha Tags to display. Seems to be a problem with ARC160 upload. The scanner was showing the tags as I manually scrolled thru the lists, but no display during scan. I had to manually re-enter the TG ID's and confirm the tags for each ID by using the PGM/ENT at the end of each one before the scanner would recognize them.
