bs953
Hi all,
I bought this scanner the other day from rat shack, I also picked up the clone cable, installed ARC300, became a premium member of this site and bought the rat shack glass mount ant.
I installed the ant correctly carefully cut the tint from around the mount etc etc. I mainly bought this scanner to listen to freqs from Mariposa County (California)( I live in Fresno) and also CHP, since I drive two hours each day. My working theroy is that if I can hear the little buggers on their mobile freq I got a cop within 5 miles of me rather than having a radar detecter tell me "they already see me". Anyways, from day one I had major issues with this scanner getting lots of noise on everything under 45 Mhz and not picking up my distant transmissions, my Pro-2044 and my OLD ten band does not have this issue, in fact the ten band literally has a coat hanger for an ant and it picks everything up including distance stations. I thought maybe the glass mount was junk, so I got the magnet mount ant and popped that on the trunk of my honda, BINGO now I am getting CHP and my distance stations. While sitting still, engine off. When I start driving though the 45 Mhz and under goes to hell, to the point that I have to shut that bank off, all of my distance works great. So now I know that the glass mount is junk, but doesn't explain the noise under 45Mhz even with the att on (which negates the mobile CHP freqs), and it is straight static full bar, stays there for a minute sometimes, then just simply stops and moves along or I LO that channel. It does pick up CHP when they talk IF I have that channel on. I have set those freqs to FM, since there not AM (learned that one the hard way), my pro-2044 doesn't have these issues in the car. Any ideas?
1991 Honda direct wire to the battery with good wire.
Other question: since I have two ant's now any reason I can't use a BNC T and utilize both of them? The glass mount worked real good for the higher freqs (dont know why) I understand ant size is inversly proportional to freq. so this doesn't work out for me on the numbers. I don't want to have nice squre hole in my tint, if I remove the ant. I can return it still and I have talked to the rat shack nerds about it. I am out about $400.00 and only frustrated. Thanx folks.
