pro-163 salem fire trunking
alfactors
salem oregon
pro-163 wont trunk fire for salem a or b tower. like the data base is missing a freq.on it.wint thro.2 scanner and gave up .eney help thank you.
kf5qgf
Olive Branch, MS
3 things to check:
1. Did you set every channel in the trunk to Motorola type?
2. Did you set the bank to Motorola?
3. Are you certain there's only one trunking system in each bank?
-Craig
DickH
Salem has been re-banded and the PRO-163 needs to have custom band plans. They can only be added using a software program.
alfactors
salem oregon
ok ty
thank for the info. craig i did a on 1 b on two with a i did not no the re baned trunk sys. had to do it with pc interface program.
Fielder3
North Willamette Valley - Oregon
Salem Fire
If you don't want to go through the computer upgrade, and want a simple way...
Just monitor them in CONVENTIONAL mode.. NOT trunking. (be sure to lock and unlock the control channel as needed each day.) There should be 4-5 800 frequencies you can manually enter into your scanner. Salem Fire is on A-tower system 99% of the time. (If A goes down then they would switch to B.)
A Tower System isn't all that busy in the day, but you will hear buses, and public works at times. At night after 5-7pm, you will hear Fire almost exclusively.
