Pro-164 Antenna BNC broke
Orbit_Uranus
Daytona beach fl
I have a Pro-164 and the plastic bits inside the BNC Antenna plug all broke off, anyone know what part I should buy and how to replace it? Or is there a place that does repairs on RS Scanners?
Thanks!
N8IAA
Fortunately, GA
Thanks!
Are you referring to the connector on the scanner, or, on the antenna itself?
If it's the rubber duck, there are many options to buy a replacement antenna. Amateur Electronic Supply in Orlando would be one. Or even the Shack itself.
If It's the connector on the scanner, you might want to ask at the Shack if they will do repairs.
HTH,
Larry
jaspence
Michigan
BNC replacement
If RS can't/won't fix it, you could try a two way radio dealer. BNC connecters are not a proprietary part and any dealer that sells HT's should be able to replace it.
