I have a radio shack pro 164 I have the frequency of 155.145 when this appears I also have C T 179.9 Search, what is CT and why is it telling me to search? can someone please help me on this
The CT code or CTCSS (Continuous Tone-Coded Squelch System): "It is a use of sub-audible tones that are transmitted along with the speech portion of the transmission which allows more than one agency (or fleet) to use the same radio frequency without causing undue interference to another agency on the that frequency. Receivers for agency XYZ are set to only open their audio squelch when the proper sub-audible frequency tone is part of the transmission."
For example; if Dothan police are using 155.145 as a car-car channel and Houston county uses the same frequency as sheriff tac channel, then when one agency talks the other agency would hear it. With the CT codes, each agency can have a separate code but still use the same frequency without interference from each other.
When you programmed 155.145 into the radio the receive mode was set to CT but no tone code was entered, then when a transmission occurs on that frequency the radio goes into CT Tone Search mode, in your case it has decoded the tone as 179.9. When in the search mode and while a transmission is in progress and a code appears, press the ENT key and it will save that tone code to the frequency.
This also works the same way for DCS codes.
Hope that helps.
Keith,
