Pro-164 picking up all talkgroups
SharpTJ
So I have programmed the scanner with all of the trunked frequencies. Using the ARC 300 software, I set the bank to MO and each frequency to MO. I entered each talkgroup ID in the appropriate field, but when I scan it does not pick anything up.
davewhall29
Knoxville, TN area
If you could post the system you are trying to listen to, then someone might be able to help you out. Thanks.
davewhall29
Knoxville, TN area
OK, yeah Knox County has changed CC and added new frequencies to cover added traffic. I have that system loaded into my 163 (mobile version of 164) and hear it just fine using the info in the DB.
Good to know it's working.
