Pro-164 problem
kcvanover
Philpot, KY
My Pro 164 has developed a strange problem, it receives the 800 mhz band 12.5 khz high.
853.8375 is received on 853.8500. it is constant across the whole band. The lower bands are uneffected.
Is there some offset I might have turned on by mistake? Any ideas?
thanks
mikey60
Oakland County Michigan
thanks
If it's trunked, check to make sure you don't have the system set as a Splinter system.
Mike
kcvanover
Philpot, KY
Trunked as ECACS. Checked all banks, no splinter. Just upgraded firmware and initialized, will try with a fresh load of frequencies.
