As I said before , I bought this scanner new yesterday and here it is all day today already trying to listen to this and it still is flickering between the two frequencies , I thought that the pro 164 scanners should come with the rebanding supported but evidently this one seems to not , my pro 95 and pro 97 that i have all I did was enter the frequencies and they worked fine but this darn one does not work.If it is supported do I need to spend more money for the cable and software to get this one to work , if so I should have bought a better brand with less headache and enjoy the holiday.
As has been noted several times above, as well as on the page
linked a couple of times, the Pro-164
will work. But you do have to enter the rebanding table information
via software, and send that to the scanner.
You are confusing the firmware for the scanner with programming software, calling the 1.07 firmware version "software. It is not. You need to use either PSREdit300, ARC300, or Win97 to enter the rebanding tables, along with the control channel frequencies and talkgroups. You will also need the programming cable to send the information to the scanner.
If you want a scanner that requires no programming software to be purchased separately, then perhaps consider returning the Pro-164 and getting the
Pro-107 instead. It has the database information in the scanner, updated weekly. (The same basic scanner is sold under the GRE label as the
PSR-700. GRE makes the Pro-107 for Radio Shack.)
