When I turn the squelch knob it make scratchy sounds. Loose wire? Normal?
rad1oreference Member Joined Dec 3, 2007 Messages 122 Location Live Free Or Die Apr 4, 2014 #1 When I turn the squelch knob it make scratchy sounds. Loose wire? Normal?
rad1oreference Member Joined Dec 3, 2007 Messages 122 Location Live Free Or Die Apr 4, 2014 #2 I do hear the comms well though. But it never used to do that sound before
wheels63 Member Joined Jul 29, 2006 Messages 115 Location Wisconsin Rapids,Wi. Apr 4, 2014 #3 Sounds like it is dirty.Buy some tuner cleaner to clean it.It comes in a spray can .Radio Shack should have it .I`v cleaned a few on my scanners. Tom
S SquierStrat Member Joined Aug 22, 2008 Messages 771 Location Fremont NE Apr 4, 2014 #4 Normal for this scanner. Contact cleaner will fix it right up
rad1oreference Member Joined Dec 3, 2007 Messages 122 Location Live Free Or Die Apr 16, 2014 #5 So i will need to open the scanner or spray on the SQ knob itself?
WA0CBW Member Premium Subscriber Joined Dec 8, 2011 Messages 1,616 Location Shawnee Kansas (Kansas City) Apr 16, 2014 #6 You might be able to remove the knob and "drizzle" the cleaner down the shaft but normally you would spray the cleaner directly into the potentiometer. This would require opening the case and maybe removing the circuit board to get to the pot.
