I did quite a bit of searching, and still am not coming up with an answer to the following:
Using PSREdit to program. I have all of my frequencies programmed in a bank on my PRO 164. I programmed talk groups that I want to listen to along with the text tag for each TG. Here's the problem though.. when the scanner receives a transmission on a TG in that bank, only the frequency number shows up, not the text tag.
I'm not sure if I'm programming wrong, or if there's a setting on the scanner I missed.
Thanks in advance!
Thanks in advance!
