kwells
Hey guys, this is my first post here so forgive any newbie jargon I might deliver. I have a new Pro 164 and I have tried programming in trunked frequencies, I've looked all over this site and gained a lot of knowledge but it's still not scanning; I will explain how I've set it up and any help would be appreciated.
First of all I used the directions in the manual and entered the frequencies in starting at 001 thru 015, including the 000.000's for 3 channels as was I instructed. On the initial Trunk screen this is the way I have them set up (I think this is where the problem is)
Line 1: ID BANK 0-0 ON
Line 2: EDACS TGID# 00
Line 3: ED NONE.
I'm also using a recieve mode of FM, tried changing to ED because the police here use EDACS but that didn't work
Set up this way my scanner doesn't Trunk scan; I hear a lot of annoying buzzer sounds and a lot of beeping with a few transmissions in between.
If it is the TGID#'s I need, I cant find them and I don't know what ID 0-0 ON means either.
I live in Davenport, Iowa with zipcode of 52806. The police use EDACS and the frequencies are in bank 001-015. Oh and when it scans these frequencies the "T" never comes on the screen.
Any help will be most appreciated
Thank you
Kent
Line 3: ED NONE.
Thank you
Kent
