There is a BUG in the firmware version 1.06 for the PRO-164.
I have an inquiry to GRE asking them if they gave the newest 1.07 version with the fix to Radio Shack. My current reply status is...
Let me ask and see what's up here. There should be a RS version for every GRE version that is published.
I'll get back to you.
Jack
GRE Support Team
GRE America, Inc. - Powered By Kayako SupportSuite
Here's the info regarding the 1.07 GRE firmware.
Latest release of PSR-300/400 "CPU G1.07" Firmware has been released.
CPU Firmware Version - G1.07 - 04/07/09
Corrected a problem with EDACS operation where certain control channel
frequencies would not track properly.
The frequency storing condition which generates the problem:
When the same frequency is stored in the control channel of Motorola System
and in the control channel of EDACS System, the software does not decode
EDACS Control Channel data properly.
Note: CPU Version G1.00-G1.05 does not generate this problem.
With the scanner turned OFF
Press and hold the PGM key while turning the scanner ON
Scanner should read...
Boot Ver:T1.00 - - (or F1.01) You will need the correct boot version of the software to upload
App1 Ver: 1.05
CPU SW Upgrade
Wait for PC/IF
