Pro-18 Backlight Programming Question
soboss34
South Salem
I just got a RS Pro-18 and am inputting playlists, etc. I would like the LCD to light up when a channel is active (like it does on my PSR-500), but don't want it on all the time. My question is: I want this set on all of my channels. Is there a shortcut to applying it or do I have to go through the iScan playlist and manually click and set backlight on each frequency??? Ugh...hope not.
Thanks for anything you can tell me.
mikey60
Oakland County Michigan
Click on one object, then Press Ctrl-A to select all objects, then set the alert settings. This should set them for all of the selected objects.
Mike
