Intellifax
- Joined
- Jun 17, 2003
- Messages
- 139
- Reaction score
- 0
On my PRO-197, The ATT setting is backwards on some conventional VHF objects. So far I've only noticed it on about 3 objects. Either scanning or manual, the signal meter shows a large signal on those objects if the ATT is off, but the signal is actually very, very weak, like the attenuator is actually on. It's OK on other objects. To receive that object (getting used to used to the object/frequency/channel language...), I have to turn on the ATT, the big A now appears at the top, the signal meter then operates normally, object comes in loud and clear.
I've reloaded the scanner via both WIN500 and ARC500, using clean files that worked OK before. I'm sure its not the software. I've pulled the power and let it set overnight. I've done both types of resets (Global Parameters and Factory Defaults) and reloaded using a clean file. Still does it.
It previously worked fine on these objects, now its not. The problem could be worked around by setting the ATT for these objects, but that wouldn't cure the problem. Any ideas on what else I could check? TIA
