Michael-SATX
OK, Dusco25 by default the "Global Attenuation" is enabled on the Pro-197,(Also try Squelch Knob at 11 O'Clock)
So next please lQQk at your display while scanning and see if you see a "GA" indication on the top display line ?
If so, try turning it off by first pressing the "FUNC" key then the "ATT" key to disable global attentuation.
So now with the "GA" gone from the display while scanning please retry your Conv P25 reception.
Being the Conventional UHF P25 tower is 17 miles away, please NO ATTENUATION should be
enabled and thus snuffing down your reception by 20 decibels, you want better RX and not worse
Do yourself a favor and try this easy and obvious expirement and let us know your RX results ... OK.
btw ~ If still no better results, I also have to suspect the BNC jack maybe being bad or a cold solder joint to the PCB
One of my Pro-197's has an issue until I twist off the BNC antenna connection enough so it is not securely locked,
then wa la the reception is completely normal like my other Pro-197 Scanner RX.( How strange is this rare issue right ?)
To tweek how loose I wiggle off my BNC antenna I use the TSYS signal strength % percentage reading while tweeking.
When I get my normal 99% TSYS RX, I know I have my sweet spot or temporary workaround, when I have time I will go inside
and see what this units actual problem is ... either a bad BNC jack and or a broken solder connection. Hope this helps you !
