Hi all,
I got this scanner less than a week ago, and I have a couple of questions about it. I'm basically trying to determine if it's defective, because I still have three weeks to get it replaced by RS if it is.
1. I've mentioned this in another thread, but didn't get any kind of definitive answer. So here goes again. I've noticed that the signal meter is always displaying on my scanner. I understand that when scanning trunked that the signal meter is showing the strength of the control channels when nothing is coming through, and when receiving a broadcast, it's the strength of the incoming broadcast. I've also heard that the signal meter can display when scanning past a channel with the squelch mode set to CTCSS or DSS. But my signal meter is always showing. As an experiment, I entered one channel into a scan list. This channel had the squelch mode set to None. The signal meter still showed up while just scanning that one channel. I have Win500 installed on my computer. When I plug it into the scanner and start the monitor, the Signal is always showing something, and it seems to go along with the signal meter. Can anyone confirm or deny whether my 197 has a problem? My PRO-163 never shows the signal meter until I'm receiving.
2. I'm noticing some problems with the scanner cutting off the beginning of transmissions. Sometimes I get half the transmission and sometimes I get nothing but a keyed mike for a second. This seems to happen on most frequencies, but is particularly bad on the one trunking system I have programmed in. After reading the following thread: http://www.radioreference.com/forums/showthread.php?t=129895 I set the DG Int Prime value to 30. That's the only reference I could find to fixing this issue. Is there anything else I can do, because it is particularly annoying not to be able to hear entire conversations most of the time.
Thanks guys.
2.
Thanks guys.
2.
