Pro 197 Frustrated
fyrefghter746
Barnesville, Ohio
It's me again and I'm getting frustrated with this scanner. Please Help!! It's a Radio Shack Pro 197 and I can program a conventional freq. from Cleveland Airport and pick it up fine, however if I try to program a talkgroup from Belmont Co. (ohio) I get nothing. Not sure if i'm not programming right numbers in the right places. I thought if I subscribed to RR that I could find even more useful information but I can't find any more frequency info than before without buying more online software (which I really don't wanna do)
Any tips, tricks, or advise would greatly help
Thank You
Chris
Highpockets
New Jersey
Thank You
Chris
What software are you using?
fyrefghter746
Barnesville, Ohio
ok, when i look at the system talkgroups for belmont county, i see the letters "DEC", the decimal format thats used for programming trunk trackers. My question is this... when i make a new talkgroup in the scanner, where does this number go, or do i even use these numbers?
ST-Bob
Worcester, MA, USA
You need to add the trunked system as a new object and then add the system's frequencies as objects related to that system. Then you add the talkgroups and relate them to that system. Object-oriented scanners are a whole new world. You might be better off with the software and cable.
fyrefghter746
Barnesville, Ohio
I finally figured it all out after 2 days, the scanner is doing exactly what I want it to do. thanks to all for the help, I was about to give up but with time and patience I got it!! and would you believe I went through all this just to program a scanner for a friend...now I just need to figure out what kind of scanner to buy for myself. Seeing how I have the PRO 197 down pat, maybe one for myself!!
