I have my PRO-197 mounted in my vehicle wired to the "always hot" accessory outlet. The scanner works fine until I start the vehicle; then when the power momentarily shuts off when I turn the key to start, my scanner shuts off and displays "low voltage" and must be turned off and back on. Is there any way to prevent this other than trying to remember to turn the scanner off and back on every time I start the vehicle? I tried adding a 1-farad 16 volt booster capacitor in the line to provide some buffer current while starting but this does not always work. Has anyone else had this problem? Never had this problem with the conventional Bearcat scanners and I'm stumped.
