PRO 197 or the Uniden 996XT
dhughes20
Findlay Ohio
I am having trouble deciding on a scanner I live in Findlay and I want a scanner that gives me everything and covers everything and I can get my money's worth. And I want to make sure if Findlay ever decides to switch back to Analog I can still use my scanner.
wa8pyr
Technischer Guru
Lead Database Admin
Ohio
Both will work well for what you want; however, the Pro-197 has much cleaner digital audio, and since you're in a digital zone now, that would be an important consideration.
The Pro-197 is also much more flexible in programming; there are 20 scan lists per virtual folder (or "personality" if you like) and you can put any object (frequency, talkgroup, search, etc) in any, multiple or all lists if you so desire.
AMDXP
Rawson, OH
Also Consider the PSR500/600 (mobile/base) from Grecom. They make the Pro 197 and some of the other RS models. The main differences between Gre and RS is that you would be able to get firmware updates faster and the Grecom includes the Power Supply and Data Cable. You have to buy those separate at RS.
Edited to add:
My PSR500 is feeding my Hancock/Putnam Feed. I love it!
ibagli
Ohio
RS includes the power supply with the Pro-197 (but not the Pro-106).
ATFD286
Findlay, OH
Doug,
I purchased a Pro-197 last year and love it. I am not a scanner guru by any means though but I found the Pro197 to be very user friendly. The programming was also fairly simple using the ARC500 software. I too live in Findlay and just recently reprogrammed mine to listen to the secret police.
