Pro-197 programing problems
macari77
Downriver, MI
Ok, got my new Pro-197 and programmed Downriver Mutual Aid and Western Wayne County M-Aid. I have the Radioshack discone antenna mounted on a mast on my roof. The problem is that Western Wayne M-Aid will show 3 to 5 bars but will only come in when it wants to, sometimes it will be only static, very garbled, no sound, or starts out perfect then cuts out and come back (or dose not come back) ...
If anyone can help me with the Win500 programming I would appreciate it.
Also Detroit simulcast on MPSCS 701 has 1 to 2 bars signal, but no sound at all.
iMONITOR
Silent Key
S.E. Michigan
Where are you located in relation to the systems you're trying to monitor? The Radio Shack discone is not the best choice for monitoring 800MHz systems. How high is your antenna, and what type of coax are you using? How long is that coax?
macari77
Downriver, MI
About 4 miles away from the coverage area.
On a 5 foot mast on top of my two story house.
50 foot Radioshack coax (nothing special).
Also I should add, there is a forest behind my house which sits in the way of the signal. Trees are about as tall as my house or 10 feet higher. Forest is about a quarter mile think. Think that could be a major problem?
iMONITOR
Silent Key
S.E. Michigan
The 50 feet of nothing special Radio Shack coax could be part of the problem. At 850MHz the wrong coax can suffer a lot of loss.
Have you tried your radio upstairs in the house with the stock antenna to see how that performs?
macari77
Downriver, MI
My 800 rubber ducky does not get the signal anywhere in my house. However when I walk my dog I usually take the pro-96, with good weather I will get the signal when I am out of the house. I really think the forest behind my house is killing the signal. Think my 20 element yagi will be able to power through the forest?
diskmonger
Michigan
If your not within the city limits of Detroit your going to have a problem hearing that system. Try upgrading your coax to LMR-400 or something similar.
