Pro 197 signal strength
krokus
Southeastern Michigan
Wirelessly posted (BlackBerry8530/5.0.0.973 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
What frequencies do you have programmed, and systems are you trying to listen to? What are you using for your antenna?
jeffpenland
gooding id
pro 197
have discone on the roof about 10 feet above the roof 800 mhz trunking pro 163 does fine the new pro 197 from what i understand is i have to input talk groups which i dont understand. i have had scanners for years this one has got me upside down lol thanks jeff
W2PMX
Fayetteville NC
Talkgroups have nothing to do with signal strength. If you receive the signal, and it's weak, you might have a bad scanner. Or the 197 may just not be as sensitive as the 163 (and it won't overload on strong signals as easily).
N1BHH
Jackson Square, East Weymouth, MA.
I don't think returning it for another one will do any better. This radio is more sensitive to trash all over the spectrum. Using the Global Attenuator may help you out. If you are in a high RF environment, if you can see a cell tower, then you'll need attenuation.
There are also several other global functions that can be adjusted. The easier to read manual is available online.
Easier to Read Pro-106/197/PSR500/600 Digital Scanner Manual
coloradomom
Colorado
I had the same problem when i first got my pro-197 .
BUT I HIT THE TUNE, and set it to about 10 minutes to the hour and it works great like that .
I can get local SO and PD ,and reach out to about 153 miles .
I HOPE THIS HELPS YOU,
Good luck
