Pro-197 Squelch Tail
BlueDevil
WA
Even with the proper squelch settings entered into the channel I am still getting a horrible squelch tail at the end of every transmission. I feel like I am listening to and old school regency crystal scanner. I was hoping for better technology than this. Any ideas on what I might be doing wrong or is this just the way it is?
Thanks!!
TRNcommLLC
Monongahela, PA
I have the GRE version of that scanner but never had that problem. Are you using a CTCSS or DCS? My squelch is kinda tight.
Have you edited anything with software?
I use the ARC500 and there is setting in "Expert" tab that can cause problems if your not careful.
John
N8IAA
Fortunately, GA
Thanks!!
What is the frequency?
Larry
BlueDevil
WA
I have been using some software but it was doing the same thing before I was using the software. I have my mode set to auto. Maybe if I changed it to FM it would take care of it?...
BlueDevil
WA
Changing the mode to FM didn't help anything. The scanner seems to wait to close until the carrier drops instead of losing the Squelch Tone....
W6KRU
Oceanside, CA
Thanks!!
There is an adjustment for that. I think I lowered RF SQ fade to 2 or 3 from the default level of 10 and had a nice short squelch tail on my PSR-500: http://marksscanners.com/106_197/106_197.shtml#RF SQ Fade
BlueDevil
WA
Thanks DDan!!
I adjusted the HD5 setting from the default of 2000 to 200 and the scanner is working perfectly!
AC2OY
Belleville,New Jersey
Wow nice glad you got it fixed. If I ever played it those menus I would get in trouble because I have no clue what most of those setting actually were.
