So, I programmed my 197 with some conventional frequencies. It was working just fine, but I decided to delete all my frequencies and re-load them manually to better organize them.
After loading the frequencies just like I did the first time, my scanner won't scan. I can listen to one frequency using MAN button, but I can't scan my other frequencies on the same channel. I get a message like this:
G
Nothing enabled!
1................ pri
(the 1 is flashing)
I've re-loaded the frequencies, pressed the SCAN button and restarted the scanner. Nothing works.
Any ideas? Thanks!!!
G
Nothing enabled!
(the 1 is flashing)
