Pro 2006 30 Kc Filter 30-88 Mhz
NDRADIONUT
FARGO ND
Has Anyone Found A Decent 30 Kc If Filter Replacement For The 2006 To Monitor The 30-88 Military Band With Less Distortion ??
Thanx !
Hooligan
Clark County, Nevada
Thanx !
Wow, are you really hearing enough single-channel/non-secure military traffic in the 'Fox Mike' band to make it worthwhile to mess with a PRO-2006 that way?
I assume you're mostly hearing some range control & Dustoff nets.
Newer scanners such as a Uniden BC-785/796/996 have NFM, FM, & WFM modes, with the 'FM' mode being wide enough to provide decent audio for the 30kHz-wide analog FM deviation military 30-88MHz radios.
Back in the day when I was SIGINTing that stuff a lot, I'd use a PRO-2006 for scanning/searching, but then when I heard something decent, I'd monitor it on an Icom R-7100 using it's medium FM bandwidth mode & a military surplus 30-88MHz log-periodic.
Tim
NDRADIONUT
FARGO ND
I Have 6 Of Them So I Figured Id Make One Of Them For 30-88 Stuff With The 30 Kc Filter And Maybe Another One With A 12 Kc Filter Since A Lot Has Gone Nfm.....
prcguy
Does the 2006 use the little black plastic filters or the longer rectangular metal ones? I have a drawer full of filters and some probably 30KHz. I also have a PRO-2004 at work somewhere but am too busy to find it and crack the case.
prcguy
