Pro-2006
Spirit
Larimer County, Colorado
I have a friend that just bought a Pro-2006 from ARC. Can he get digital on it to pick up Loveland PD, ect.? He also wanted to know if he could get Denver Edacs? He doesn't have a manual for it. Does anyone know where I can download a manual for him? I looked an couldn't find anything. One more thing, if he can get digital can he use Win 500 or PSR 500/600?
kruser
Well Known Member
W St Louis Cnty, MO
Those were great radios but no digital support.
As far as Edacs goes, he could program in the voice channels and hear them but he cannot track them as the 2006 is not a trunk tracking scanner. I'd guess trunked radio systems were still on the drawing board when the 2006 was made.
They are also not computer controllable at all unless they have been retrofitted with one of several add ons made by a few different outfits.
None of which are available any longer unless one got very lucky and found one on eBay or something. I'd think you would have a better chance at finding an entire radio that had one of the interfaces installed in it already before you would ever find an uninstalled interface. They are just way too old.
edit: a pdf scan copy of the owners manual is found at the very top of a simple google search: http://www.repeater-builder.com/radio-shack/pro-200x/pro-2006-om.pdf
Spirit
Yes I did find the manual on Google search but was just trying to find one that was not sideways. I tried to turn it around but couldn't. Thanks for the input on the scanner.
Halfpint
Slightly NE of the People's Republic of Firestone
Is it *just* a PRO-2006 or does it happen to have a DB9 connector on the back and *possibly* something mentioning either OPTOscan or OPTO456 on a sticker someplace? While it may be a longshot that it does have the DB9 connector & something about OPTO456 some place on it, it *is* albeit only a conventional (Non digital capable) one heck of a good scanner. (It's the last of in the line of the RS-2004/2005/2006 "Super Scanners" and there are a whole bunch of interesting `tweaks-n-mods' that it can have done to it that enable many different uses. (I'll admit that I've got *several* of them ranging from a couple `in need of some care' 2004s all the way up to 2006s with OPTO boards and other interesting tweaks and mods. Currently a pair of 2006s reside in my current `radio stack' and while not always in use they still see a fair amount of use even in these days of DTRS and other trunking and digital systems.)
Unfortunately, as kruser has already mentioned your friend won't be able to use it to monitor any of the trunking or digital systems here in CO. But, despite that, your friend will be able to monitor a lot of other things, even some things that most of the newer radios can't. (Though, if it hasn't had any of some of the usual, usually done right out of the box, mods there are some frequency ranges it won't cover. [Someplace around here I still have, I think, a list and instructions for all the `out of the box' mods and if I can't locate them right away I suspect that there a *several* other people who can.])
All in all, even with it's lack of the newer formats, it is still one heck of good fun radio.
