mojobreakfast
- Joined
- Nov 15, 2005
- Messages
- 57
I was at my local thrift store today and came across a like-new Pro-2018. For $20 it was mine.
Upon plugging it in, I discovered that the volume control does not appear to really work. It is though the volume is at about 90% of maximum at all times, even when the knob is turned down. If I crank the volume "up" it will go the remainder of the 10% to maximum.
This is regardless if I use speakers or headphones and is obviously a quite annoying failure or defect.
I popped the volume control circuit board out, inspected it for bad solder joints, sprayed some air on it to remove any dust/particles, but no dice.
All other functions of the scanner work fine. Anyone have any ideas?
