Pro 2025
moochie
Clarksburg, Philippi, WV area
I recently came across a pro 2025 scanner, the other ones I've seen have the so for 12 volt power.jack. The one I have acquired has 3 wires hardwired. 1 red, 1 white, and 1 black. I know the black is ground, and I'm assuming the red is constant +12 volts and the white is switched +12 best volts. Does anyone know if this is.correct?
dave3825
Suffolk County NY
The 2 manuals I looked at only mention red and black. When you pull the barrel connector out of the scanner, does the power barrel connector jack look like this? Just a ground blade a 1 center pin?
krokus
Southeastern Michigan
The manuals seem to be for the 20-146, and you have the 20-146A. The power cord is a difference, so it is best to just have someone open up the unit, and verify your pinout.
