Ravenkeeper
Finally got power, antenna, and external speaker connected, tried to scan the presets in Police/Fire/Ambulance, and all the frequencies were "000.0000". WTH?!!!
I don't know about the preset frequencies, the PRO-2026 won't retain the channels you program with without power to scanner. If you remove the power it will need to be reprogrammed.
This scanner is very old in terms of the scanners and much has changed, since these were new.
If it's anything like my old Pro 2036 was ... there's a 5 yr battery that acts to hold the memory inside the circuit board. Sadly, mine was SOLDERED on and not removable. It didn't matter as by the time it finally gave up and never held the memory after being unplugged, we had gone to Digital Trunking here locally and beyond. I got rid of it. Your battery is dead most likely and will not remember anything after being unplugged. It's an old old scanner
