Pro-2050 problem
wa9ave
Hi all,
I am new here but thought maybe someone else has ran into this problem. I have the above scanner and it worked well up until about 2 weeks ago. Now, it SAYS it is scanning but the squelch won't open. I have checked the ant. with another scanner and it is fine. I reset the unit. I even opened it up to look for possible signs of smoke. All to no avail. If I turn the sq. knob I can get it to make noise but it still doesn't get any signal.
I would like to try to fix it as I don't have the $ to get a new one.
Any help would be great,
Kevin
WA9AVE
Nordland
Great lakes state of MI.
I do not understand what you are trying to say.....you say the squelch won't open...then you say you can hear noise?
Program in your weather station...they are on all the time...if you cannot recieve the weather station...then somethings wrong with the scanner...it would cost you more to have some tech to fix it than it would to just buy a new or used scanner!
