wyldman
I recently purchased a used 2050,and cannot get it to trunk our local Motorola type II system.
I've programmed all the control channels,and the voice channels.It will scan and recieve voice traffic in non-trunked mode.I have it set to trunk Motorola type II,but no luck when I activate trunking.It searches,finds the correct control channel in use,then just sits silent.Once,for a brief second I heard some traffic,but it was so quick,I couldn't make out what it was.
I have also tried setting it up as a Motorola type I or hybrid,with all the different plans,but no luck.It is made by Uniden,and all my other older Unidens will track this Motorola II system just fine.Hit the trunk button and off it goes.
I did some searching,and found this will only track analog Motorola type II systems.Does this mean analog voice ? or analog control channel ? (if that even exists).I though all control channels were in a digital format.
This is the system I am trying to monitor.
System Name: Peel Region
County: Peel
System Type: Motorola Type II SmartZone
System Voice: Analog and APCO-25 Common Air Interface
Sysid: 543d
Last Updated: Changed talkgroups
Hits: 9550
There isn't much APCO-25 stuff,and none in any of the groups I want to monitor.Full link to system is http://www.radioreference.com/modules.php?name=RR&sid=1573
Any ideas to get this beast to trunk this system,or am I SOL.
County: Peel
Sysid: 543d
Hits: 9550
