PRO-2052 IDs
keithmj
Saint Petersburg, Pinellas County, Florida
Hi..First post as you can see. I am using the PRO-2052 and was wondering what software would show me not just the frequencies but the Talkgroup IDs? I am trying ID Tracker but from what I can figure out this is only going to show me the IDs that I already have programed into the radio. Or is there a way to program it to trunk without the IDs put in..I have the PRO-2053 and the IDs shows on the screen but the PRO-2052 doesn't. Is there someway that I can just by scanning have to IDs show up?..Thanks..Keithmj :D
LarrySC
Greenville, SC
Run it in the "Search" mode. Should show all ID's on system. I have Digital 796 and 96 but use a 2050 in search mode for a commerical MOT system in my area. Usually just run it at night. Looking for rental radios, PVT Inv, Security and secret stuff. Good Luck
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
keithmj said:
:D Thanks..Something so simple. I'll give that a try. But won't that just show the frequencies? Trunking start at the 800 freq and my scanner starts around 32.000 when I hit search? :p ..Cheers..Keithmj
I do believe Larry meant ID Search mode (where you are not using any preprogrammed scan lists), as opposed to ID Scan mode (where you are using a scan list). IDTracker will record every talkgroup encountered as unknown, and keep a running tally of how often each one is used. You will see the frequency that the talkgroup is using, but that will not be recorded.
73s Mike
