Hey everyone.
So I'm trying to program my Pro-2055 to trunk frequencies found here: http://www.radioreference.com/apps/db/?sid=5121
I set up Bank 0 to be Motorolla Trunked, and
Channel 0 to be the first controlling frequency
Channel 1, 2 to be the alternatives
and a couple of other channels listed in black on on the link above for our area.
The problem is when I'm in manual mode (because thats al I can figure out how to work)
I have also entered several 5 digit codes also found on that link
The display shows:
M000MO 159.39000
pri att DLY lo+
Bank 0 Chan 00
MOT: Control: 20%
MOT rotates through varying Control %s and SYS-880: never goes above 50%. I was lucky to get both around 80% at one point, but I never heard any audible change.
Sometimes the scanner will display a matching 5 digit code, but I never have audible recoginition of it (just the static).
So what am I doing wrong, or do I just have no signal? Hard to understand because the tower/location is the same as a standard FM frequency that I recieve clear as day.
I've done alot of reading to understanding trunking, and want to learn about it, just having trouble getting this to work. Did I miss a step?
Thanks!
The display shows:
M000MO 159.39000
pri att DLY lo+
Bank 0 Chan 00
MOT: Control: 20%
Thanks!
