PRO 2055 LTR question
kd5dga
Killeen,Texas
I was reading some of the WIKI reference on the PRO 2055 and PRO 97 scanners. Since the PRO 2055 and PRO 97 are similiar will the PRO 2055 function like the pro 97 does when locating a LCN order for LTR.
Here is the link for the PRO 97 information;
http://wiki.radioreference.com/index.php/Pro-97
Here is the text version;
Finding LTR LCN order
The PRO-97 has a feature that will tell you what the proper channel number for an LTR system is.
  1. Program a frequency from the system in the first channel
  2. Set the mode for LTR
  3. Put the scanner in manual
  4. When you hear a transmission, there will be a number in the lower right corner of the display like "R03" or whatever. This is the LCN (Logical Channel Number) of that frequency. If it is "R03", you would re-program that frequency into channel number x03 where x is the bank that you are going to use.
Continue the above procedure until you have all the numbers for all the frequencies in the system, keeping in mind that some numbers might be skipped over, example, there may be no channel R02 in your particular system.
Note - The LTR repeater number identifer does not work when the repeater ID burst is turned off by the system administrator.
